Assigning part numbers
This tutorial describes how to assign parts from the catalogue to the components in your project, as well as how to save new parts to catalogue.
Parts list, component, catalogue, part number, assign part number, assign component, assign catalog part, assign from catalogue, symbol properties, modifying properties, pin numbers, linking multiple symbols
- Creating/modifying catalogue parts (4:49)
- Adding a fuse to a fuse holder (1:00)
- Linking symbols together (2:38)
- Changing pin numbers (2:57)
- Managing parts lists and BOMs (3:02)
- Showing components properties around a symbol (1:00)
- Making graphical groupings (4:13)
Written version
When you assign a part number to a component, much more than simply the part number is assigned to component.
All the information pertinent to that catalogue part is assign to the component, which may include the manufacturer, image, description, pin numbers, layout views, etc.
By assigning catalogue parts to components, you will benefit from many of SkyCAD’s automated processes, such as automatically generated parts-lists and bills of material,
proper pin numbers associated to the appropriate symbol’s connection point, previewing an image of the component when it’s selected, properly dimensioned 2D layout views with clearance distances, direct access to the part’s online spec sheets, and many other features covered in other SkyCAD tutorials.
Instructions
There are several methods to assign catalogue parts to components:
Select symbol(s) on a sheet
Select component(s) in the tree view, parts list or BOM
Set default part number for a symbol so when inserted the component is automatically assigned with that catalogue part
All these methods require the catalogue part to already be saved to your catalogue.
If the part is not yet saved, see if it’s available from the Online Parts Catalogue.
If the online parts catalogue doesn’t have the part, you can easily create it yourself following the Creating/modifying catalogue parts (for basic components) or Block generator (for more complex components; e.g. with I/O) tutorials.
1. Select symbol(s) on a sheet
Select the symbol(s) on the sheet, go to the Home tab and select Assign from Catalogue
Choose the part you want and click OK
2. Select component(s) in the tree view, parts list or BOM
Select the project in the tree view, go to the Home tab and select Components, Parts List or BOM
Select the component(s), go to the Home tab and select Assign from Catalogue
3. Set default part number for a symbol so when inserted the component is automatically assigned with that catalogue part
Right-click on a symbol in the symbol library and choose Open Block
Explore the properties of the symbol in the tree view
In the Default part number property enter the part number of the desired catalogue part exactly how it appears in the catalogue
Right-click on the symbol in the tree view and choose Save As, suffixing the file name with the part number
The default keyboard shortcut for Assign from Catalogue is F5.
