Online Catalogue questions and issues
Ask questions or suggestion about the online catalogue, and submit issues with particular parts available on the Catalogue.
About the online parts-catalogue
The SkyCAD online catalogue is a collection of electrical manufacturer parts in the SkyCAD file format, which were all created by SkyCAD users around the world.
If you download parts from the online Catalogue, whatever part you make or modify yourself in the future could automatically get sent to the catalogue, making it available for download to all other SkyCAD users around the world.
https://skycad.ca/parts-catalogue
motorized valves
motorized valves
are there any motorized valves on the online catalog? i tried searching for anything but nothing shows up.
eg: caleffi z111000
Jumper representation symbol in the library for terminal block
I looked into the catalog library but wasn't able to locate any symbol for jumper which I woud like to include in my BOM. Is there any symbol available for a terminal block jumper ? I thought about applying the fuse symbol but the terminal blocks are fairly small and the fuse may not fit.
In addition, i am also thinking about terminal block partition, terminal block end covers when installed on a din rail. It would help if you can share some idea how I can capture it and generate in the BOM
Thanks in advance.
Wago Lever Nut
Wago Lever Nut
I am trying to create an ES that uses Wago Lever Nuts as the connectors. I currently have a model that is a one to one wire connector (image attached) but in this schematic I am using 3 and 4 connector lever nuts. Are there any pre-made lever nut models that I could have access to? Or could someone possibly lead me in the right direction in order to get this done?
circuit breakers 1+N where can i found
i cant found circuit breakers 1+N in the site and in the programme and i need this exist somehow i can to search for
the image just for exemple dont lock at the enterprise
AutomationDirect C0-16ND3 contains wrong content? Or am I doing something erroneously?
Hi All
When I'm trying to import the package C0-16ND3-20230612163502 from the online catalog, a permanent error is produced (see screenshot). I extracted the content from the archive and saw that skycadfile is a terminal but not an IO module.
Is it possible to fix this issue? I'm new in SkyCAD, sorry.
Thanks in advance!
Multiple names to 1 manufacturer
Hi I'm spending a day going through tutorials as we have chosen skycad for our electrical drawings. I noticed when looking at adding equipment to the Parts list that the online parts calalogue sometimes has the same company writen different ways eg
Flow Switch
Flow Switch
I can't find a flow switch symbol - IEEE.  Has anyone made one?   I expect it should be in Sensors/Switches
Catalog Parts - Comments
Would it be possible to add a Note column where comment/review are added by users?
This will help to share additional information/comments, which end users could review before a part is downloaded. In this example the image and layout do not correspond to the Part number. Also, the AC terminals are top, however, depending on the disagner the power terminals night be L (top), N(bottom).
PhilJ
ABB XIO-08
ABB XIO-08
Does anyone have a cad drawing of the ABB Totalflow XIO-08 ?
