Adding fuses to fuse holders
In this tutorial, you’ll learn how to add fuses to your fuse holders.
Fuse, fuse holder, fuse switch, fuse terminal, accessory, save to catalogue, assign from catalogue
To add a fuse:
  1. Select the fuse holder/terminal/switch (from the tree view, parts list, or by double-clicking on its symbol)
  2. Go to the Create/Add tab and select New fuse
  3. You may have to scroll down to see the fuse that was added (or go to the Show tab and select Accessories)
  4. Explore the properties of the fuse, enter the details (part number is the most important), select the fuse and choose Save to save it to your catalogue for future use, as you would for any other component
  5. Selecting a fuse holder/terminal/switch which contains a fuse and saving it to catalogue, will save the fuse holder/terminal/switch including the fuse, so that next time that fuse holder/terminal/switch is assigned from catalogue, the fuse(s) will automatically be included
  6. If you’ve entered a value in the Current property of the fuse, it will display near the fuse holder or fuse terminal
Fuse terminals shown in terminal strip layouts, will have an F if they have a fuse in it
