Block generator - Example drive
This tutorial is an addition to the block generator tutorial, as mentioned at the 3 minute and 14 second mark.
Please watch that tutorial, up to 3:14, before following this one.
This tutorial gives more examples of adding IO and other terminal types to a component in the block generator.
PLC, PLC modules, drive, soft-starter, IO, input channel, output channel, analog input channel, analog output channel, digital input channel, digital output channel, relay output, digital output module, digital input module, analog input module, analog output module, symbols, blocks, terminal name, terminal label.
