Changing the title block on a sheet
This tutorial covers how to replace the title block on an existing sheet with a different title block you have saved.
If you have not yet created the desired title block, refer to this tutorial first.
Change title block, replace title block, change template, replace template
Main Content
- Select the Symbol Library heading:
- Go to the Create/Add tab and select Add library folder
- Name the folder something like Title Blocks, click OK and it will be added to the Symbol Library
- Expand the new library folder: e.g. Title Blocks
- Go to the Home tab and select Add existing graphical object
- In the directory, go up one level to the graphical block folder
- Open the Title block folder and double-click on the title block file you want. It will be added to your Title Blocks folder in the Symbol Library
- Select the title block on the sheet and hit Delete
- Insert the desired title block from your Title Blocks symbol library folder just as you would insert any other symbol
