Hiding certain graphical objects when printing
This tutorial is an addendum to the Printing tutorial.
This tutorial covers how to have graphical objects visible in SkyCAD, but have them hidden/invisible when the sheet/project is printed.
Hide symbols, hide blocks, hide text, invisible, not print, print
Main Content
You may want to have certain graphical objects (symbol, drawing objects, lines, texts, etc.) visible in SkyCAD, but invisible when the sheet/project is printed. For example, on a sheet, you may want to add personal notes, or construction lines that allow you to achieve uniformity throughout the sheets in a project, neither of which you want visible when the sheet/project is printed.
To make a drawing object (from the Drawing tab) on a sheet invisible when printing, double-click on it to explore its properties, then de-selected the Printable property.
To make a symbol (from the Symbol library) invisible when printing, right-click on it and choose Explore block or Explore connection (whichever is applicable) to explore the properties of the graphical object, then de-select the Printable property.
- Printing (2:29)
