Version 1.3.26 change log
Version 1.3.26 is now available for download.
Here's an overview of fixes and added features.
Added features:
V1.3.25
Allow to link Connection ports to connectors through the Block Generator tab.
Add process that ensures connected connector pins match the connected pin value.
Add possibility to number pins based on list of values.
Offer better options when user types in WorkID values that already exists
Allow wire crossing loop on connections
Improve library folder creation
Allow to isolate component/wire numbering by rung number sections
Make it so 'Open in new tab' opens the component layout view when layout instance is selected.
Open terminal strip view when double-clicked from main tree view.
Add auto-scroll ability to view tab tray
Add "Close all except selected one." to hamberger menu of view tab area.
Add auto-scroll ability to graphical editor when moving objects and reaching the border
Add auto-scroll ability to library folders when moving objects and reaching the border
Add auto-scroll ability to tree view when moving objects and reaching the border
Allow to display library folders in alphabetical order.
Add auto-scroll ability to ribbon
Allow to show ribbon item text in Ribbon
Allow to customise keyboard shortcuts
Make so 'Link with' can be clicked on tree view item on second click.
Allow to show terminal strip list as Grid.
Display Root object displayed label as a prefix in View tabs when more than one root object is open.
Allow generated blocks to have several connection ports with same name.
Implement a 'Dark mode' to the SkyCAD UI
Add the possibility to add accessories to connector pins
Selected wire renumbering/processing should renumber net
Add 'Selected component renumbering' item in 'Renumbering process' tab
Bugs fixed:
V1.3.26
'Quick tour' button in Welcome window points to more recent video.
V1.3.25
Assigning a pin to a connector does not properly re-link connection points.
Make it so a connector pin can be none-flow-trhough by default
Deleting a layout does not trigger deletion of the elements inserted on it.
Single wires can't be hidden from catalogue -- property not available.
Layout representations do not get selected with when selection box is used.
Two files can get created with the same internal ID
Refresh is required after flipping cable in order to see results flipped in cable wire list.
Dotted lines and Axis line types not properly exported to DXF/DWG
Twisted pair cables should be created as virtual parts by default.
Connection graphical sorting depends on connection drawing orientation, and it shouldn't...
Sheet with 'Printable' property uncheck should not print.
'Draw line' property on closed drawing objects not copied when using format painter.
Improve wiring path calculation logic for OPRs, based on OPRs direct links with one another.
Direct navigation not applied when second representation is a layout instance.
