Changing OPR orientation
This tutorial will show you how you can change the graphical orientation of an off-page reference.
OPR, OPR orientation, Flip OPR
When inserting OPRs through the 'Insert and link OPRs' tool:
OPR orientations are defined arbitrarily by the software in the following manner:
As you can see, OPRs will point towards the right on horizontal connections, and towards the bottom on vertical connections.
You may wish to show the arrows pointing in a different direction, based on the flow of current or signal of the connected elements.
To do so:
- Select the OPR you wish to flip (make sure to select the actual OPR symbol, and not its cross-reference text.)
- Click the 'Flip OPR' button, from the 'Home' tab.
The selected OPR should then point in the reversed direction.
