Version change logs
V1.3.65 change log
V1.3.65 change log
Version 1.3.65 is now available for download here.
Here's an overview of fixes and added features.
Added features:
V1.3.61 change logs
V1.3.61 change logs
Version 1.3.61 is now available for download here.
Added features:
V1.3.39 change log
V1.3.39 change log
Version 1.3.39 is now available for download.
Added features:
V1.3.39
V1.3.38
Issue when deleting a sheet in the context of an option with content related to old revision.
Version 1.3.26 change log
Version 1.3.26 is now available for download.
Added features:
V1.3.25
Allow to link Connection ports to connectors through the Block Generator tab.
Add process that ensures connected connector pins match the connected pin value.
Version 1.3.13 change log
Version 1.3.13 is now available for download.
Added features:
All Pro features now available.
Version 1.2.197 change log
Version 1.2.197 is now available for download.
Added features:
Version 1.2.131 change logs
Beta-Version 1.2.131 is now available for download.
Added features:
- Add parts from catalogue directly from the panel layotu view.
- Use SHIFT to make a multiple cell selection in spredsheet view.
- Allow 'Assign IO' to all components, not just PLC Modules...
V1.2.112
V1.2.112
Version 1.2.112 is now available download.
Added features:
- It is now possible to hide wire color info displayed beside a cable indicator.
- Extended list of location (Location and their sub-locations) now displayed when assigning a component to a location
- Environment structure file automatically restored from Time Machine is error ocurrs loading it.
- 'Tutorial' button added in 'Print' ribbon tab.
V1.2.107
V1.2.107
Version 1.2.107 is now available download.
Bugs fixed:
- Some projects would crash on opening if they referenced a symbol or part that got deleted and no longer exists. This issue was introduced with the previous release (V1.2.104).
- It was impossible to select more than two elements at once. (V1.2.106)
V1.2.104
V1.2.104
Version 1.2.104 is now available download.
Added features:
- It is now possible to change sheet size.
- Select sheet
- Click 'Home/Change sheet size'.
- Block generator: Generic terminals can now have multiple terminals.
- Hold SHIFT when adding a generic terminal and enter number of terminal to create.
