Version 1.2.131 change logs
Beta-Version 1.2.131 is now available for download.
Here's an overview of fixes and added features.
Added features:
- Add parts from catalogue directly from the panel layotu view.
- Use SHIFT to make a multiple cell selection in spredsheet view.
- Allow 'Assign IO' to all components, not just PLC Modules...
- Allow for partial views of Layout representations on sheets.
- Allow graphical elements not to be printed, but still show on screen.
- Performances with large projects improved.
- Provide the ability to delete a class setting.
- Allow numbering follow-through on entire block.
- Take into account cell multi-select whe assigning 'Connected To' to IO.
- Allow adding IO symbols on the fly
- Possibility to remove revisions from a project (keep the current one only...)
- Changing channel type is now be possible
- Allow creating part assemblies
- Double-clicking in the Explorer should not always trigger a close of the window.
- Time machine now deletes archive older than 5 days.
- Allow quantity property tp be equal to 0. (But not less than 0...)
- Disable SHIFT key on com port creation in Block Generator
- Bridges not drawn when terminal strip layout is split
- Elements using sheet numbers in their tag keep original sheet number when copy/paste sheet(s).
- Renumbered elements using wrong query to sort; folders are prioritised and they shuoldn't.
- Folder table of contents does not list sheets in sub-folder.
- Print from print preview creates a blank page
- Icon file locked when added from Catalogue tools.
- Graphical elements with 'Displayed=FALSE' changes position in treeview.
- Review reset of Titleblock coordinate offsets when switching to/from line numbering columns.
- Table of content list block not updated in real time when sheets are added to folders
- Saving a cable indicator in context should reset any applied rotation prior to saving.
- Copy/Paste through click-and-drag from tree view allows even if project is revision locked.
- Crash when layout instance selected after canceling line segment creation
- SkyCAD loops if default environments path is not a valid one.
- 'Display in catalogue' property not present for cables.
- Element name being printed shown instead of total number of sheets printed.
Bugs fixed:
- Fixed 'Value cannot be null' saving bug.
- SkyCAD stops rendering sheet when a text with an unexisting font exists.
- 'Replace connection type' should replace connection even if it is of the same type.
- Block generator Relay output icon depicted as in input when IEC library is selected.
- IO Channels display IEEE 'Right/Left' info even if working in IEC (Should show 'Top/Bottom')
- Net branchs get deleted if the first connection found on net does not have a net branch defined.
- Bridge lines not drawn when exporting to DWG
- Query cell refresh issue (when 'Allow edit'...)
- Renumbering components renumbers terminals even if manually numbered.
- Modified catalogue parts not saved when using 'Save All'
- Empty thumbnail after regenerating block
- Cross-references not displaying on cable indicator symbols.
