Terminal strip management
This tutorial covers how to organise terminals within your terminal strips, such as sorting and moving terminals around, bridging terminals, and adding terminal strip accessories, like end stops and separators.
Terminal, separator, end stop, moving terminals sorting terminals, connect, disconnect, bridges, bridging.
Ribbon buttons' appearance and positions may differ if you're using version 1.3.25 or higher; e.g. Wire Number column renamed to Net Number, and Wire Type column renamed to Net Type.
- Introduction to terminal strips (6:57)
- Terminal strip layout (6:00)
- Stacked terminals (3:35)
- Terminal connection point blocks (2:00)
- Numbering process (6:30)
