All tutorials
THE FOLLOWING LIST OF TUTORIALS IS NOT IN ORDER!
Take note that the list of tutorials displayed is not in the order the tutorials must be viewed, but rather in order they were last created or modified.
If you wish to follow tutorials in the order we propose, refer to the Get started, Get better and Get flying lists.
Converting heavy layouts to images to improve performance
This tutorial explains how to reduce slow performance (lag) by converting component layouts with many drawing objects into images.
Panel layout, layout view, component layout view, dwg import, dxf import, heavy layout, lag, slow, performance, time
Single Line Diagrams
In this tutorial, you will learn how to create a Single Line Diagram (SLD).
Single line diagram, SLD, one line diagram, single line connections, link symbols, link cables
Main Content
Symbol Library, Catalogue & Other Fundamentals
In this tutorial, you will learn the difference between the symbol library and the catalogue, as well as other fundamental concepts and relationships in SkyCAD’s architecture: classes, sub-classes, catalogue parts, catalogue, symbols, blocks, symbol library.
Understanding how these elements relate to each other will improve your experience.
Link terminal symbols to terminals
This tutorial explains how to link terminal symbols to terminals already existing in terminal strips, which may be needed if you did the panel layout before the schematics or added terminals to a terminal strip without using terminal symbols.
Link symbol to terminal, link symbol to TCPB.
Changing the size of an enclosure
This tutorial explains how to transfer location layouts from one location to another.
Follow this tutorial if you want to change the size of a location without having to lay out the elements again.
Change layout, change panel size, change enclosure size, change cabinet size, change panel part number, change enclosure part number, change cabinet part number
Changing the title block on a sheet
This tutorial covers how to replace the title block on an existing sheet with a different title block you have saved.
If you have not yet created the desired title block, refer to this tutorial first.
Adding Port Types
Adding Port Types
When creating a component in the block generator, the Port Type column defines the appearances of the ports.
In this tutorial, you will learn how to add more port types.
Adding connectors to components
In this tutorial you'll learn how to assign connection ports to connectors in the block generator.
If you haven't seen the Block Generator tutorial, please watch that first, then come back to this tutorial.
Terminal connection point blocks
In this tutorial, you’ll learn how to depict individual terminal junction connection ports using Terminal Connection Point Block symbols.
