All tutorials
THE FOLLOWING LIST OF TUTORIALS IS NOT IN ORDER!
Take note that the list of tutorials displayed is not in the order the tutorials must be viewed, but rather in order they were last created or modified.
If you wish to follow tutorials in the order we propose, refer to the Get started, Get better and Get flying lists.
Link terminal symbols to terminals
This tutorial explains how to link terminal symbols to terminals already existing in terminal strips, which may be needed if you did the panel layout before the schematics or added terminals to a terminal strip without using terminal symbols.
Link symbol to terminal, link symbol to TCPB.
Changing the size of an enclosure
This tutorial explains how to transfer location layouts from one location to another.
Follow this tutorial if you want to change the size of a location without having to lay out the elements again.
Change layout, change panel size, change enclosure size, change cabinet size, change panel part number, change enclosure part number, change cabinet part number
Changing the title block on a sheet
This tutorial covers how to replace the title block on an existing sheet with a different title block you have saved.
If you have not yet created the desired title block, refer to this tutorial first.
Adding Port Types
Adding Port Types
When creating a component in the block generator, the Port Type column defines the appearances of the ports.
In this tutorial, you will learn how to add more port types.
Adding connectors to components
In this tutorial you'll learn how to assign connection ports to connectors in the block generator.
If you haven't seen the Block Generator tutorial, please watch that first, then come back to this tutorial.
Terminal connection point blocks
In this tutorial, you’ll learn how to depict individual terminal junction connection ports using Terminal Connection Point Block symbols.
Pin-out blocks/attributes
In this tutorial, you’re going to learn how to add pin-out information to component layout views and create dedicated pin-out blocks for components.
Pin-out, layout, connection point, port, wiring diagram, wire, point to point, add pin-out attribute.
In this SkyCAD tutorial you’re going to learn how to add pin-out information to component layout views to enrich your panel layouts with wiring information (see black text below)
Add Channels to Block
In this tutorial you’ll learn how to add terminals to a block which has already been generated by the block generator.
Block generator, add channels, add terminals, add ports
If you want to add terminals to a block created by the block generator, but don’t want to generate a new block, you can use the Add Channels to Block feature.
Block generator - Example drive
This tutorial is an addition to the block generator tutorial, as mentioned at the 3 minute and 14 second mark.
Please watch that tutorial, up to 3:14, before following this one.
This tutorial gives more examples of adding IO and other terminal types to a component in the block generator.
